When shifting from 1st to 2nd...sometimes the bike will go into neutral...actually it's been doing it alot lately and its pissing me off. And I'll try to ease it into gear when it does that and it gets real clunky...anyone have any suggestions?
This used to happen to me before I had riding boots (bigger toe) and now it rarely happens. You could adjust your shift lever down a notch or get some boots.
Check the clutch cable tension too. I know on mine when I first broke in the bike, my 1st - 2nd transition got a a bit sloppy as the cable stretched a bit. I keep a slight bit of play in the lever and find that neutral is easy enough to find, without me slipping into it ever.
