alright this question does not relate to kawasaki my buddy rides a katana and if your sitting on the bike the header pipe all the way to the right is just about cold after 15 minutes of running i cant barely touch any of the other 3 but the 4th one i can wrap my hand around and leave it there all day long so what do i start looking for
You have a cylinder that is not firing. Check plug, coil and plug wire and see what happens from there.
so don't check plug wire, coil, or plug check before doing a compression test?:headscratch
Well, since you have to pull the plug to do a compression test....might as well have a look at it :lol
And just to add one more possibility, it could also be the carb. Either because of plugged jets or flooding (see fouled plug). Anyways, definitely not firing on that cylinder.
