1992 Zx-7 i want to remove the gas tank to get to the plugs, i know there are four allen wrench bolts, but are you able to disconnect the tank and the fuel line without gas leaking all over the place. thanks
U Should Be Able To Disconnect The Fuel Line From Your On/off Valve. There Should Be Two Lines To The Vavle Then One Line From The Valve. Good Luck!!
Yup I concur, just be careful when lifting the tank as the rubber hoses might be brittle from their age. When I lifted mine the line snapped, no biggie though just gave my bike a gasonline cleaning!!!:eek:hno
