1 - 14 of 14 Posts
I get around 125 miles to a tank of gas.I'm getting a power commander soon so hopefully that will change!!!!!!!!
Stock I was getting 39 to 41 mpg while commuting (125 mi per tank before low fuel light came on) in the 70 to 80 mph cruising range. With a PCIII custom map and GIPRO ATRE I get 38.5 mpg (110 mi per tank before low fuel light comes on). I'm adding Akra bolt-ons tomorrow and I'll see if this changes...
im getting, 110 miles per tank before the light comes on. I do some sity and some freeway driving
OK...This is what I did.
I emptied my tank and put exactly 4.5 gallons back into it. This puts the full fuel level at about 1/2 inch above the bottom of the filler neck. I rode it like I normally do, commuting 45 miles round trip daily. Approximately half of that is interstate. On this particular fill up, I know that I took the bike above 120 6 times and just generally being frisky with the throttle in spurts.
My fuel light came on at 138 and some change. I took it easy from there on, only hitting 130 once during this time and the engine sputtered at 181 and some change and died at 182.
I have no doubt that if you took it easy, you could get to 150 or so before reserve and close to 200 per tank.
My bike is a totally stock 07.
My light generally comes on 110-120. Current average is 39, best I ever got on a tank was 45 mpg, worst was 36.
I've noticed that if I ride hard, or like a grandma, mpg doesn't really change that much. Think about it, even at 100mph, you're only at 6.5k rpm. That's only half of what it's got.
I don't know if it's because I'm an enormous wind block or not, but I get exactly 100 miles out of a tank before the light comes on. No matter how I ride it....
I just bought an 07 ZX 10R SE. My fuel light came on today at 140 miles, I could still see fuel in the tank, but I filled up, 3.18 gallons. I figured I had over a gallon still in the tank. I had to fill up because I had to ride 45 miles to do a computer job, so I couldn't see exactly how many miles I would get on a tank and I didn't want to push it home. Hopefully I can find out with this tank.
I did a run today to see two things, how many miles to the gallon and how many total miles on a full tank. I filled the tank sitting on the bike holding it upright, if you fill it on the kick stand, you don't quite get it completely full. I got 189 miles on the tank, 42 MPG. The breakdown on how I ran it, about 70% highway miles, 30% around town. My fuel light came on at 133.3 miles, and it quit at 189. This test was done on an 07 ZX10R.
Hmmmm....sounds familiar...lol
Grease's Gas Tank Test
Just checked mine and I got 38. I put in 3 gallons when the light came on. Supposedly I still have 1.5 gallons left before it goes dry. Do the rest of you have the light go on with 1.5 left?
Hmmmn...? :headscratch Every time my gas light goes on, I fill it up as soon as I can and I've never put in 3 gallons. I usually end up putting in around 2.25 to 2.50 max. So it looks like mine goes on when there's about 2.0 gallons left.
three times now have I ran the tank to 170 miles and on fill up it takes about 3.4 gallons so that would mean I have approx one gallon left.
1 - 14 of 14 Posts
