1 - 10 of 10 Posts
Hey guys,
There is a pipe that runs down the bike from near the bottom of the tank that has been leaking gas. ( there are bout 3 coming from different places). The full tank I had for storage leaked out of that pipe throughout the last month. Its directly connected to the back of the tank. Is it an overflow or something else? .. What should I do?!
Thanks
· Premium Member
How did you set the tank down?
It could have been leaking from the cap and then down from around the rim of the gas cap. If you spray water at the gas cap you will notice that there is a drain for that area. If the tank is stored "upright" or on one end, gas WILL leak from the cap.
· Premium Member
Did you over fill it?
Which line is leaking?
· Premium Member
There is more than one pipe back there.
· Premium Member
What year is yours? My P model has more than one on the back of the tank.
Perhaps you should take pics and point out the offending hose.
1 - 10 of 10 Posts
