So my gas gauge doesn't work on my 98 zx11 I bought called the guy he said he replaced the tank with a 96 tank could that be the reason or maybe he didn't hook up something please help
The first thing I would check is the electrical connections on the bottom of the tank. If both of those are clean & tight I would follow the wires and make sure they are plugged in to a connector under the seat. When you go to pull the tank off you should have to disconnect the gas guage wire, if you don't then it isn't hooked up...
