The zzr1100D is almost back together. Just ready to start it. Does the fuel pump need to be primed before it will operate ? There is no sound from the pump relay when ignition on. Should you hear a click when it operates?. All fuses appear good. The pump works ok when connected direct to a battery. An to ideas guys ?? Cheers
Does the bike run okay?
Well it does now !! Sussed out the pump runs when starter pressed. Float needle was stuck open on no 1 and pump filled exhaust with petrol 😭. Cleaned all the carbs out and changed the oil after taking out all the plugs and clearing the cylinders. Starts first time now and idles ok. Just needs carbs balancing. First bike I've ever had with a fuel pump😂
