Hi sorry its a long ine😁, I've got a zx12 powered mk indy kit car and has been awesome, until last weekend. Always started on the button but Friday afternoon turned the key pushed the start button and just turned over nicely but didn't fire. No codes, but fi light flashes when turning over. It was really hot that day and the next morning went to it and fired straight up. Went for drive, stopped it, then wouldn't start again. Got lt trailered home and 1hr later just fires up. Done a few checks and took it up the road and it literally just shuts down and wouldn't fire again. Replaced inline fuel filter. Now the pump doesn't always prime but when it does the flow rate is good. Now the pump and relay seems to work as should but don't always get energised. You have to turn the key on and then the immobiliser instantly to get it to prime at all. If you give it couple of seconds it seems to loose it. There is a power commander on it which I'm tempted to remove
Any thoughts, thanks
