1 - 9 of 9 Posts
hey yall, I have a 2001 zx6r with a bolt on gp race muffler from pipe werx and a k&n air filter. Ive drilled out the screws for the fuel mixture and have them set to 3 turn out. ive balanced the carbs but it seems to be running a little rich. Was just wondering what anyone else has theirs set at? Also with the bolt on exhaust, what carb settings work best? is the factory pro carb kit a good idea? Thanks.
Yes on factory pro jet kit. Idle fuel mixture screw should be set to where the bike will start easily when hot without choke. Also, it should start easily when cold with choke. I'm in FL. So, somewhere between 2 turns and 2.5 turns out works here
  • Like
Reactions: shimslady
Base setting for any fuel mixture screw will be 2.5 turns out. Rich will only help with starting and if ur going to whack the throttle at idle. Generally its just wasting fuel and fouling plugs tho. Make sure it idles right and it returns to idle correctly. Doesnt hang up when u close throttle. Generally a jet kit will make things run richer. But more responsively. Helps get the California out of ur bike so it can behave correctly
3 turns out seems a bit rich. What were they at originally?
originally they were all at different heights. turned them all in and then backed out from there 3 turns because it felt good with the throttle and choke. starts up great even when cold but i seem to get a stumble around 9 or 10k rpm in first gear only but it always pulls through.
Im up in CT, not sure if that makes a difference. I put them 3 turns out because it felt good with the throttle and choke. It starts up good when cold but ive noticed a stumble or lag around 9k or 10k rpm in first gear.
That's either going to be your needle height or main jet. Possibly a vacuum issue
  • Like
I originally had this issue about a year ago but in all gears at a high rpm and it was very laggy. I took the carbs out and realized one of the main jets was completely unscrewed inside of the carb. I cleaned/reassembled and it seemed to take care of the problem. Until now i notice it again but only first gear. Also did a vac leak check, sprayed starter fluid in near the boots and everything seemed fine no rise in rpm. I will re check for a vac leak and then take the carbs out and see whats up. For needle height, ive never played with them but i have shims. What would you suggest if anything for that? Thanks for your input!
Double check your ram air ducting first. Look for any possible vacuum leaks there. If that passes inspection, then look into your carbs. Make sure the bowls are properly vented to the airbox. Inspect the carb slide diaphragm. If they look worn, I would replace the slides. If they look fine, then leave them be. You then could try either a smaller or larger main jet. It's either getting too much fuel or not enough fuel. A sudden bog at those RPMs and 1st gear makes me think it's too rich. If it's a gradually power loss, then I would think too lean.
1 - 9 of 9 Posts
