What size fuel line do I need to buy to redo my fuel lines? 3/16 or??? I want to use some motion pro.
It is for a ZX11 if that matters
8mm or 5/16" for all lines except that there are two 10mm 3/8" custom molded hoses that reduce to 8mm connected to the inlet and outlet of the fuel pump. The fuel pump is 10 mm. If you want to replace the 10mm to 8 mm molded hoses you will probably need to buy the OEM Kawasaki part. I left the molded ones in place and just replaced the long 8mm ones that go to the petcock valve and tank. Those are all custom molded, but as long as you make sure they are the correct length and routed correctly without pinching or obstruction they should be OK.
