My front brakes started squealing recently. I took both calipers off and inspected everything, but don't see anything wrong. The pads are still like new. Can anyone recommend a fix? Is it ok to use anti-squeal compound that is used on cars?
Thanks
I would not recommend that. I have heard of very,very lightly sanding your rotors with like a 320 or 400 grit sandpaper. Enough to rough it up, but not so much as to remove any material. Good luck!
I always have been using "Brake quiet" stuff behind my motorcycle pads and I never had any squealing.
Maybe you pads are glazed if you did not broke them in correctly (if at all). Slight sanding of the brake surface could help in that case.
