When adjusting the floats,do you tip the carb so the needle valve has moved out of the needle valve seat,and then slowly tip the carbs untill the float makes contact with the needle valve?Or with the float needle all the way in the needle valve seat,then slowly tip the carbs untill the float starts to pull away from the needle valve?
Cut and paste
Tilt just enough to touch and close the float valve, but...
Do NOT compress the float valve spring when measuring... - Factory Pro
Which, with some carbs its just about possible to do while the thing is laying flat on its back, as the springs are pretty stiff.
Mine can almost manage that lol
