gonna need 4 relays. 2 for front and 2 for rear.
^im talking relays, not resistors. youll need 4 resistors but i was told only one relay to replace the stock one in order to prevent hyperflashing when using leds
Just one relay, the one under the seat on the left side.
I tried mine with both relays, and I actually left the stock relay in. Flashes about 2 times per second with the LED bulbs installed. Thought it would be more of an attention getter if it flashed faster.
Alec
Im putting leds in the front and rear turn signals. How many relays do I need? One for each signal (4)? One for front and one for rear (2)?
I found the rear relay....if there is a front relay, where is it located?
Ill be using the "LF1-S-FLAT" model found on superbrightleds.com unless someone else has something better/cheaper
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=/flashers.htm
You have the correct relay, you only need the 1 as a direct OEM replacement for front & rear, plug & play & you're all set to go. Leaving the stock relay in causes all 4 to flash wayyyy too fast. From a distance, it looks like a bulb shorting out, more than a turn signal & they're not 1/2 as bright as they are when they get a little more "constant on" time.
