1 - 8 of 8 Posts
So if everything lines out correctly and the weather stays good I should be heading to the track for the first time on my new 14R. Well I want to see what you guys think I will do at the track. I'm having an Adams arm installed (hopefully it will be done today) but other than that I will be stock. I'm thinking of taking the stock tire down to about 20psi. So knowing these anyone want to put up any guesses?
Need more info to make an educated guess.
Ever been on the track before?
As a wild guess I'll say 10.03 @ 136. If you've never been to the track on a bike.
Discussion Starter #5
Well I say I did pretty well. My best time was 9.85 at 143 with a 1.77 60ft. Only thing done to the bike is an Adams arm about 8 in back and I lowered the tire pressure to about 20psi.
not too shabby for your first time. the more you get that 60' down you will see your time drop a lot. shouldnt have a problem getting your 60's down to the 1.4's with that arm. thats what you should work on the most, the rest after that is just shifting!
9.53 146 1.51 60ft on a 12r at 1100 ft 9.73 is best at home track 3800ft. To get your 60s down lower the rear and strap the front and get a drag hookup Shinko and most important GEARING!!!! The 14 in this pic had a 1.69 60 , while the 12r had a 1.53. Never cought us!!
1 - 8 of 8 Posts
