I just bought a 2005 ZX-6R (C1) ("only" 9600km, bike in VERY good condition). Also a PowerCommander III USB has been installed last summer (2006). Unit is under rear seat.
I have now driven bout 200km and today FI-led lights up at some point and stayed on; at some point I noticed it turned off, but in the end it stays on.
Bike runs ok, no problems.
Service manual says:
"Even when the DFI system is operating normally, the FI led may light up under strong electrical interference. No remedy needed."
"...stays on -> DFI problem"
"Sometimes lights up -> probably a wiring fault"
Could it be that PC3 causes some disturbance?
Or some moisture/water in some wire junktion?
Any ideas/guesses?
Discussion Starter · #2 ·
Got sum info elsewhere; could be that some screw is bit loose, which is holding orginal exthouse-valve-servo-wires or something. The bike has also a slip-on so orginal wires are attached to sum dummy plate or sumtin...
