1 - 20 of 82 Posts
I have a GREEN 08 zx6r that I am going to part out. I am just seeing what you all might need........ :headscratch
All items will be plus shipping! I need a zip code and email to send a pay pal invoice.
No mid or lower fairings.
I have everything else though.
Front turn signals......................................$15 each
Under nose trim panel.................................$10 I have several of them
Front fender, I have Green, Black.......................$35 each
Kick Stand with electronics...............................$35
Lower OEM belly panel GREEN............................$45
OEM bulbs........................................................ $5 each
I have a full ignition with upper trip, gas cap and seat lock with OEM key......................................SOLD
Gas Tank, has 1 small paint chip. OEM w/ side trim and front mount. NO gas cap or pump....................................SOLD
Two Brothers muffler and mid pipe with hanger............................SOLD
K&N air filter...........................SOLD
OEM Nissin Front calipers w/ pads, master, res, lines and lever with mount......................................SOLD
OEM Cluster w/ 13--- miles......................................................$150
OEM harness (2)...................................... $50 each
OEM air box (I have several)............................$25
OEM ram air tube........................$40
OEM Sprockets..........................................$35 set
Rear rotor..................................................$25
OEM front cowl GREEN (pics soon).....................................SOLD
Hot Bodies windscreen...........................................SOLD
OEM rear passenger mounts, pegs and arms.................................SOLD
OEM black forks that leak and left side fender mount bent..........................Make offer.
FRAME 08 ZX6R It has no title and has a push in the left front....................................$250
OEM swing arm with spools..........................................$90
Rectifier..................................$40
OEM left and right handle bar controls............................... $35 each
Under tail turn signal kit..................................................$10
Sub Frame and under tray...........................................$85 PENDING
Head lights...............................................SOLD
Front seat.........................$40 Rear seat................................SOLD
I have alot more parts................... ASK.
need rear sets...particularly the right one
and headlights...
Bump for a good guy/seller!
Ok guys. You guys need parts still................ I am exploding the bike right now, I will have the motor dropped on Friday and get pictures up of the parts.
Ksouc what happend with the Team Green? I havent been on, I thought you were goin green?
Discussion Starter · #13 ·
I did..... I am! The part out bike was green.
Discussion Starter · #14 ·
Discussion Starter · #16 ·
I am going to be keeping the rear sets for the June ZXF ride. I am going to try and keep extra parts for the ride in case someone goes down.
Discussion Starter · #17 ·
I will have a list up on Monday with prices! :smile
1 - 20 of 82 Posts
