88 ZX750R-F2
Hey guys I've got a quick couple exhaust questions if anyone can help that would be great.
So I have a 1988 ZX750R f2 and at this moment I have full stock exhaust from front to back. But I also have a 4-1 used system on its way. So I am looking at putting a slip on carbon exhaust on. So my questions for anyone who can answer them for me is.
Which would be better Stock exhaust system or 4-1 system with a carbon slip on?
And my next question is I know there is alot of pros and cons with stubby's and long pipes.
So if I go with stock system I have a pretty good idea on what size of slip on I should go with.
But If I go 4-1 system I know I already have more back pressure as it is would I go with more of a shorty?
I don't wanna loose my high end hp nor do I wanna loose any of my low end torque. Just trying to figure out which would be best.
Any advice again would be great thanks guys.
Happy riding and ride safe
Usually with a 4-1 you will gain top end HP but sacrifice low-mid. As for shorty cans, it seems to be a current styling trend with no real performance gains.
It all depends on what you are looking for in the end. HP? Looks? Daily rideability?
88 ZX750R-F2
From what I was reading a shorty gives you more low end vs a longer slip on gives you more top end hp. As a shorty is louder than a longer one. I know the 4-1 is more of your racing style that will in terms give you more top end Wich is perfect with me. I just don't want to loose that new top end power but I'd still like to have my low end torque with my mid range daily driveability.
Will I need to jet my bike as well putting the 4-1 on?
Any change to the exhaust side will require balancing the air/fuel on the intake side. Slip on pipes don't change much, since it is at the end of the line. A full exhaust with header changes alot.
If u get the wrong exhaust u can lose everywhere, w the correct exhaust u can gain everywhere. Stock exhaust and jetting is designed to keep the politicians happy. If u put a pipe on And rejet ur carbs u will gain about everywhere except mpgs. But sometimes even there.
Ive experimented a bit w a couple of mine, my ZX11E i picked up w a broken muffler (4-2-1 header) w no muffler it was sluggish til about 8k and then it would stretch ur arms, once i fixed the muffler it had low/mid but above 8k it kinda got lazy. With my 1981 xs1100 i went thru about 13 sets of pipes (custom) before i was happy w how it worked. Ended up w 1-3/4" singles run to the rear axle w a 30 degree slash cut in em. When they were flat (uncut) u could feel the powerband "step" every 2k rpm. W the slash it blended and smoothed the powerband. Id routinely shift that at 11k. And w my jetting it gained power and torque everywhere. But it also gets about 30mpg when im running 70mph. @50mph it gets about 45 mpg. U wont usually have those extremes w aftermarket pieces tho
