Hi (please bear with my English)
I am new to this place and would like to thank you all for your support
I purchased a stored brand new GTR 2 weeks ago
I love the motorcycle.
in the first wash (i was lucky not using too much water) i realized that the water did not leak from the fuel container and i had to absorb it myself with a cloth.
Then went and put some fuel to act as if the fuel is over filling the tank, still no drainage for the excess fuel, what do you think? please i need your advice
Thank you
Did you get water in the gas tank? I guess that's what I'm reading.
if you got it in the tank you need to drain it. Water is heavier than gas and will settle on the bottom.
no water in the tank it wasn't enough to go in the tank but the drainage does not work and that is my concern
The drainage is clogged and the way to fix it is to remove the tank and blow the tubes to clear any obstruction
