Hey guys just wondering if anyone knows if the 98-02 zx6r engines can be swaped for a 02-03 zx9r
not sure on that, i can try to check for you. have you looked at the frames of each bike. if the frames are the same should be able to do it. matterfact anything can be done, guess the question is will it bolt right in or if fabrication needed. check out those frames. i know they used to be the same frame, all the would change is the motor, rear rim/tire and suspension
