Hello all, I have an '03 that has develeoped a bad miss from 1600-2800 when just warmed up, after getting through that rpm range, it runs just fine. Taking off from a stop light can be deadly as it falls on its face. It started doing this one other time and I changed the plugs, though they looked fine, and I adjusted the TPS and the problem went away, now 300 miles later it is back. I have ohmed out the stick coils, they are perfect, TPS is sitting at 1.08 volts at idle, plugs are new, can find no vaccuum leaks.
Bike only has 3300 miles on it! Yosh RS3 is the only mod, have removed the cat as well, other than that it is stock. Please Help!!
thanks so much
Have The Bike Remapped
