Hello,
I have aquired a 1994 ZX750L that is missing the engine bolts that are behind the radiator. I am thinking of buying some used bolts off an 89 ZX750 will they work? They look like they will I just want to run it past this forum. Thanks.
Go on bikebandit.com and look at the 2 different diagrams for the two bikes and look at the bolts u wanna compare and make sure they're the same.
You just need the bolts or the spacer too?
If all you need is bolts just go to a decent hardware store and they'll hook you up. Use grade 10.9 or 12.9.
Otherwise eBay has a few options for ya.
Josh
