Can anybody help ??? ZX9 1994 B1 - bike started was running perfect then went out for a ride, filled up with petrol then when I come to switch the ignition back on the ignition lights etc came on, then went off and the bike was dead no lights or any electrical power checked fuses and they all seam to be ok battery is also ok, any suggestions
not solved electrics yet
checked the earthing of the battery this is ok (checked the battery with multi meter and is showing 12 volts). also checked the circuit from the battery through to the ignition switch this seams ok there is 12 volt there on the multi meter and also if you put the multi meter on omes then this also shows continuity. Also checked the junction box this seams to be operating as per the checks in the manual. Still no lights on panel or no other power. I lost to what is wrong
is the bike still running ???
