I have a 1999 ZX9R with a dynojet carb kit installed. I have the settings set at what dynojet reccomends and have decent power but i am looking for more. Has anyone used these kits or have any suggestions on a setting that may yield a little more power. it feels a little slugish just off idle and i really have to whack the throttle hard to get the front wheel off the ground. any suggestions on settings or to help remove the slugish problem will be helpful. bike has k&n airfilter, kleen mod,& two brothers exhaust installed
Try dropping a tooth on the front sprocket & increasing preload & compression damping on rear shock. The less the rear has to settle under load the earlier the front will lift. The lower gearing I think speaks for itself.
Best way to get it setup really good is on a rolling road.
