1 - 12 of 12 Posts
Discussion Starter · #3 · (Edited)
Edited the link so it should work.
129hp
54 lbs TQ
Very flat curve.
They created a Dynojet power commander map to achieve the most efficient air fuel ratio throughout the powerband
SuperFlow Dyno numbers are using STP Correction which runs a little lower than typical Dynojet numbers.
Dyno has a fully function Ram air setup so these numbers reflect ram air induction.
That has to be the straightest curve I have ever seen in my life!! Is that because of the bike setup or because of who tuned it in??
I still can't see the picture!!!
Here's that picture.....
To tell you the truth that is ONE of a kind charts!!! That's like perfect power distribution along the powerband......beautiful!!!!:clap
Thanks zx-rider for posting the pic. I was not able to make it show up.
The curve is a factor of the pipe, intake and Dynojet PC3 map. The map is the majority controling factor. They spent about 5 hours creating the final product. I have another buddy of mine that is a wiz with maps that will do some more small tweaks in the next couple weeks.
The power band feels very linear and comes on smooth. You can get yourself in trouble without realizing how fast your going.
Pretty cool!!! Hey post up some of the finished map's!!! Thanks....
Impressive. Yeah please share those maps within this small group. :clap
is that at sea level ? dos it mater ?
Within a couple hundred feat of sea level but they compensate for that when running the dyno
1 - 12 of 12 Posts
