My 95 dies after running for for a few minutes but then it just starts right back up. No matter how many times it dies just faithfully starts back up cant figure out what is wrong with it.
Does it hold idle? Meaning does it idle at 900rpm or do you need the choke to keep it on. If so your pilot jets on your carbs need to be cleaned.
If that's not the issue could be a bad generator that is the device that charges the battery.
Good luck
found out what was up
It was a fuel pump not kicking on after the bike was started still trying to figure out why its doing that.
