Hello All
I have a 1998 ZX6R G1. Battery is fine but when I turn on ignition and hit the starter button I just hear a click from the junction box under the seat. Battery is fully charged and all other electricals seem fine (lights, horn, dash etc)
Any ideas....??
Help would be much appreciated!
Cheers
Dave
hey...if you haven't make sure the battery connections are tight and clean from any build up/deposits
Also check the connections to the solenoid & starter are okay PLUS check the condition & connections on the starter solenoid fuse.
Check the wires that run to the Clutch lever... or make sure youre pulling the clutch in... If that plug is unplugged, you'll get lots of clicking but no starting...
did you load test the battery and if so what was the voltage after ive seen batteries show full charge and after turning the key show show no charge
