Miles ?
Have you had the Bike long ?
Has it been running without issues ?
Did it just not start one day for no reason ?
Any recent work done to the Bike either by you or someone else ?
That'll get us started![]()
Yea the bike has been sitting for a while I bought it off somebody and put new spark plugs in it.has like 12k miles .I'm not sure if it started before.Miles ?
I got a new battery a couple months ago and I tried to clean the carburetor but the bolts are stripped so I couldn’t deep clean itIs the Battery Good? It should of had a new one fitted as a matter of course as it's sat for a while, Voltage drop under cranking is a common issue with starting as they CDI will require a min voltage before it will work.
I've had Batteries go bad on one cell equating to 10 volts and still spin the motor.
You may need to get the Carbs cleaned at some stage.
All right well I will try to get inside the float bowl and clean I will update when I doI assume you mean the float bowl bolts in which case you need to get inside and clean them as that is not going to help.
I got someone to clean the carb but still having the same problem still I have no idea what it could be it still cranks and cranks but doesn't start idk anymoreAll right well I will try to get inside the float bowl and clean I will update when I do
