So im splitting my crankcase to replace trans and shift forks. Im having trouble with the actual splitting part. Whats the best way and best places to pry at?
The manual should tell you if there's a pry spot. Other than that, thump it with a rubber mallet. and make sure all the fasteners have been removed If you are doing this without a shop manual, stop now and get one. Otherwise, you may be on the verge of making a very expensive mistake.
theres 2 places....one on each side....looks like a place for a big flat head to fit....but if all fasteners are out,like hammerhead said,just bump it with a rubber mallet
ok,looked at my manual.....one is right behind the clutch.....the other is right infront of the ignition rotor
DO NOT use anything to pry apart the case halves. If you nick or scar the mating surfaces it will be a nightmare.
cheers
That's why Kawasaki put the two pry areas in the cases.....they are not in-between the mating surfaces....they are molded areas
Thanks guys, i got it split and check my trans and shifting forks. THEYRE PERFECT. I mean it. These things look just like my manual and as new should. So back to the drawing board. Ill start over. So when i would shift into 3rd it would be like i was in neutral and a grinding sort of sound. Forks and trans is perfect. Are their any other options other then a smurf playing cruel jokes on me?
