Hi
Got a 96 zx-11 ninja.
valve cover gasket was blown, oil in cylinder one. had that fixed, the mechanic didnt even check the oil level which was overfilled. the psi check was
160,170, 180 & 200....my reg mechanic said thats normal....gonna have the carbs synced and adjusted.he said it sounds lie its running rich.
Does the carbs control the psi ? or the valves. the mechanic that fixed the gasket said the cams have wear them (only has 22k) and dont think he adjusted the valves
Also, is there a reason it fires up great when cold, but takes a few seconds when its hot ?
