Have a 05 zx636… would start up and dies on Cold start. Changed plugs, throttle body, fuel pump, ecu, cleaned the injectors, checked the stick coils resistance, synchronize the throttle body…. When it is warm and running, it Idles fine…. Only when it cold start, it would jump to 1400 rpm and will jus die down and shut down. Even if I turn the rpm all the way up, it won’t idle fine until it reaches like 130 degrees.
