Well if your clutch is slipping under heavy load like mine does them id say its time. :)
what exactly is making you question yours needing changed?
like you said slippage under heavy load or launch dragging on take off and getting hard to float the gears at times
a buddy said it might be my carbs but it hard to believe carbs can do that much
Nah carbs will make the motor bog down and lack power, clutch will slip out of gear.
Sent from my SAMSUNG-SGH-I997 using Motorcycle.com App
