I've got a 1990 ZX11. After a couple weeks the clutch lever gets spongy. I've rebuilt the clutch master cylinder, replaced the clutch line with a steel braided line and no difference. I just ordered a new piston seal for the slave cylinder but I have a suspicion it's the master cylinder itself. A couple years ago I went through the same thing with the front brakes, I measured the inside of the master cylinder bore only to find the bore I/D was wider in the first 1/2 inch. I think the same thing is happening in the clutch master cylinder. Anyone else go through the same thing?
Yep it's been bleed, absolutely no air in the system. When it does go spungy it takes very little bleeding to get it strong again and no air comes out.
Prolly isnt it, but the Clutch release mechanism also has a SEAL in it
P/N 92049, Seal, oil Piston.
I was thinking the same thing so I ordered that seal from a bike shop. When I replace that seal and if it doesn't fix it I'll just have to look for a newer clutch master cylinder....it looks like a zzr1200 is the same as the ZX11.
