1 - 10 of 10 Posts
Sometimes when under hard acceleration my engine revs pick up a lot more then the bike accelerates. It feels like the clutch is slipping and mostly happens when I change into 3rd and open the throttle up 100%.
I assume the friction plates have probably worn so the clutch can’t grip hard enough. I use semi-synthetic oil and have heard that some oils can cause the clutch to slip?
What do you guys think. Should I just buy something like this?
http://www.ebay.co.uk/itm/Kawasaki-...13?pt=UK_Motorcycle_Parts&hash=item33744e9509
Cheers
Shrapers
I bought an EBC clutch kit for my 94 ZX7 and when my buddy at the dealership went to install it, he said it wasn't correct. He used OEM friction plates. I would go with OEM so you don't risk overspending.
I've read mixed reviews about the EBC clutch kits.
From what I've gathered the OEM clutch plates are the best.
Mine was slipping so I cleaned all the plates, de-glazed the steels and fitted heavy duty
springs, just replaced 3 of them as recommend on the forums.
No slippage since then even when flat out in high gears, track days etc.
Mine was doing the same thing. Replaced the frictions and the steels with OEM ones, no more slipping clutch. From what I gathered, unless you're doing anything outside of daily riding, no matter how hard, OEM is your best bet for performance and durability.
To be honest I think if I have to take the clutch out i'll prob just change it.
I can’t find an OEM “kit” so I priced up the parts separately. I read that there are 8 plates? So with 8 of the friction and steel plates The OEM works out a bit more expensive then the EBC kit at £113. New OEM springs are about £5 each! You can by an EBC spring kit for about £10 so might go with that.
What sort of problems have people being having with the EBC stuff? I thought they were supposed to be pretty good. :headscratch
Cheers
Shrapers
my bike has ebc kevlar friction plates which i cant give a thumbs up or down on because my bike came this way. i can say that compared to oem, the ebc racing springs give a better feel to the clutch lever in my opinion as well as everyone who has rode my bike
Youll need 8 frictions and 7 steels. I've heard the ebc kits are the best bet outside of OEM so its a safe bet to go with. Don't forget to order a new clutch cover seal as well.
I recently was having the same problem, I just went with 10% stronger springs ebc i believe and everything is working great, no more slippage. Cheap and easy to change out, I would say try that first, might save you some money and time.
1 - 10 of 10 Posts
