I am referring to the following when I say clutch release:
"A" in the picture above
The manual says to rotate this 90 degrees to remove, but how do you reinstall this? I'm putting a bike back together and I can pull this straight up out of the case. My question is: how is this secured into the case/clutch?
I think it has a little notch cut at the bottom of the rod.
Once its orientated into the proper position it will grab & not come out.
Of course you need to attach the cable to it.
I did pull it out enough to see that notch (thought it was damage since it looked odd to me). I'll try to reorient it in the slot. Did I break any seals or do harm by pulling it out of the case? I noticed there is only a spring, washer, and the rod according to the service manual. Do I need to replace any seals before I try to "lock" it back in (there is oil in the engine in case that matters).
Thank you, oldninjadude, for responding!
