I got my new engine installed. Ran into a delay because my clutch line had a leak in it so I replaced it. My concern now is that long push rod that sits behind the Slave Cylinder is sticking out too far, causing the Slave Cylinder not to sit flush with the Sprocket Cover. I tried to push it further in but it will only go in about 2-3mm. Looking at my old engine it seems to be in alot further. Is this normal or is there a trick to get it back in?
Thanks,
ZX11 Ryda
This is going from memory of 6 years or so ago, but I think you will have to tighten those 3 bolts in very evenly as the slave cylinder gradually pushes the rod in. Have patience, it will go in there.
