Hi guys. I am new to the forum and will post up a proper introduction post shortly after this. I have just recently acquired a 2005 Kawasaki zx636 from a friend. The bike is overall clean looks like it's seen it's side once or twice but no major issues I'd say. I do however know very little about the origin of the bike. My problem is that something is up with the clutch. With the clutch adjusted all the way out if you pull it in and put it in gear the back wheel does not lose pressure so basically my clutch is not engaging. But if you start the bike and pull the clutch it makes a wierd whistling or whining noise. I would compare it to sneakers on a Pro basketball court sound but it's constant as long as the clutch is in, also if you put it in gear it stalls out. So plz what is wrong is the clutch just bad and need to be replaced or is it something else. Thanks in advance
