1 - 9 of 9 Posts
Hello Everyone,
Just purchased a 2000 ZX-11 with 4k miles on it. This is actually my 1st sports bike. I feel that the clutch is slipping on the machine. Is there any way to adjust it? I have the service manual but it doesn't mention adjusting the clutch on this. It is hydraulic so maybe that has something to do with it. Any help would be appreciated....
Jeff
It's hydraulic. You'll need to replace it. Not a big job. I just did mine...installed a DP clutch and springs in my ZX1100E. Took all of about 45 minutes. Don't forget to get a new gasket for the clutch housing. Have some Lithium or Moly grease with you to grease the 'pusher' and the roller bearings.
DW
I just purchased the bike a couple weeks ago so I don't know about the abuse part. The guy who had it kept good care of it except when he stored it. I actually had a good car tech ride it this week end. He's stating that it's not the clutch that slipping after all. It appears to him that it's running on 3 cylinders until you gain a little speed or shift up a couple gears.
Just a guess, but maybe the first owner that you bought it from tryed to do burn-outs, but didn't have any luck, so he gave up and sold it...
I'd also suggest that you just change it and start fresh....
If it's had that little use it's probably blocked jets unless the carbs were drained down during any periods of non-use, though check air & fuel filters are clear & in good condition first & drain float chambers to check for any other crud or water in the fuel.
Long term the pilots jets will tend to block up with gummy residue where the fuel has evaporated off. If you don't want the hassle of stripping the carbs do a couple of doses of fuel system cleaner first to see if that clears them out.
1 - 9 of 9 Posts
