1 - 12 of 12 Posts
I just finished cleaning the carbs on my 2000 6R due to some crystalized particles in the float bowls. Now she won't start. Is there a trick to filling up the carbs? It just sputters every now and then.
make sure the pump is working ,float bowls have to fill back up.charge your battery
I took the line off the carbs and the pump is working. I opened up the drain screws on the bowls and fuel came out of each carb. Battery is charged. Still wont fire.
i had that happen once ,might have to change your plugs? if it trys to start and wont and sputters its the plugs
The thing is, it ran fine 2 days ago. It just needed a little carb cleaning.
Well, the fuel is a bit old so I'm going to drain it and throw some fresh gas in. I pulled a plug, it was a little wet but not fouled. Hopefully it's just the fuel.....
Well, it still wont start. All I'm getting are little bumps here and there and some backfiring through the carbs and pipe.
It ran just fine 2 days ago???
I took a plug out again, connected it to the coil pack and grounded the plug via. test lead. When I first cranked it over I had one or two bright sparks. From then on, just weak spark.
Any ideas?
New plugs coming tomorrow.
Check battery voltage while its cranking. Had this problem with my old G2 model. When the day was warm cranked and fired. On a cool morning cranked ok but not enough voltage left to fire CDI. New battery solved the problem.
gammac
Discussion Starter · #10 ·
SHE'S BAAAAAAACK! Turned out to be the plugs. Thanks Phil.
No Problem,i Have Flatslides On My Bike And I Know All About Wet Plugs ..good Job
1 - 12 of 12 Posts
