1 - 8 of 8 Posts
Hello guys..I own a Zx 6r 2011 and initially I had issues with the bike having a hard start..I changed the spark plugs and got new one,changed my stater coil since it was partially burnt and got a new regulator rectifier...on testing the bike I noticed that everything was running well and the battery voltage was okay but after taking the readings I found that it could get to 13 volts...so I went for a ride so that the bike could charge as its in motion..on my ride the dashboard went blank after 10 kilometers and the bike started to cut power on the engine ..and after sometime the bike went off completely and I had to be towed since it couldn't start even after pushing the bike to jump start it...could the battery have a an issue since a replaced everything on my charging system ?
Sent from my HTC One M9PLUS using Tapatalk
Discussion Starter #6
Normally that's pretty short battery life, but possibly a cell or two got burnt when the other stuff fried.
Just found that the stater coil on the phases that one of them was faulty ...
1st phase was 24 ohms
2nd 24 ohms
3rd one was 0 ohms
And that's why it wasn't charging my battery
The battery life is still okay
1 - 8 of 8 Posts
