Does anyone know or have a diy on how to change the levers on a ZX9? 2000/ Just ordered a new aftermarket set and cant find anything on it. Thanks guys!!
If its anything like the 7R, you simply undo the nut or bolt from the bottom side of the lever and pull the lever off.
Yep. Undo the bolt and nut...It will loosen the whole bracket of the lever. Pull the cable towards you, then through the hole and slide the peg out.
Installation is reverse.
