yea guys I just got a DID chain off ebay its 112 links will it work or will I have to get a few links took out of it? I know the bike calls for 110 but thought it might work if adjusted a bit further out..thanks
It might work for a little while but all chains stretch out when used thats why you have to keep adjusting them. I would just get a couple links knocked out. You don't want to have it stretch and not be able to tighten it up.
Thanks for advice, yea that would suck think iam just gonna take her down to shop and let them take a few out.
its really easy to remove links yourself. use a grinder and grind the end of the pin on the link you want to remove. once you grind the end off it will come apart really easy. you don't have to worry about damaging it because the one you are grinding on is going to be disposed of anyway.
