On a 07 zx6r, how the hell do you get the cotter pin out? I was sitting there like a retard trying to get it out to no avail. I tried using some needle nose pliers and just trying to pull it out and nothing. The owners manual just says, pull the cotter pin out which is absolutely no help. The rest of the adjustment would be easy if it wasn't for this damn pin :banghead
Anyone want to help me out here? thanks
I don't have mine yet but I'll assume its the same as on my current bike. The cotter pin should have a longer end bent up around the axle nut. You have to use the pliers to bend the long end back so its flush with the shorter end. Should look like this before you pull it out.
This seems really obvious, so I'm kinda thinking yours isn't this type. If not just try pulling harder, just don't lose grip and smash your fingers off of anything.
Ya i bent them in and what not, was just in there really f'in good. Finally got it out. Thanks
