1 - 11 of 11 Posts
If I put straight pipe there instead will I see a gain? Will it set off any trouble codes? How does it sound?
Don't know mate, but that is my next mod on my ZX6R, although I just want to gut it all out and maintain the standard look. See my thread on rear box and valve mod.
Won't throw any codes on a US bike as there are no O2 sensors. It will get louder and apparently there are some small gains to be had.
There is a header set on sale at EBay right now with exactly this modification you are talking about done to them from a racebike that was waiting to get it's aftermarket exhaust.
The problem on the CAT is that it has two pipes going in and one coming out, so you will have to get someone to make-up a two-into-one if you cut it out. It is a single piece from the headers to just after it turns up to the rear pipe.
i'm hoping they come out with header that will bolt up to the 2bros pipe. all they'd have to do is make a system that would work w/ the factory exhaust and then it would work with any slipon. hopefully someone will
1 - 11 of 11 Posts
