Any suggestions need new . head gasket on my 99 zx9r . So while I'm in there need to no what cam I should get to really juice the old girl make her feel young again help.
+4 ignition advancer helps with throttle response. You'll have to search online for aftermarket cams if you're trying to give it a little more oomph.
Never had to change a cam cover gasket, even though I have done more shims on zx-9r than I can count, replaced a few plug aperture seals though.
Set your valves to .30 on the exhaust side and .18 on the inlets, get pair of valve tolerances close together whenever possible the engine will run soother.
Exhaust valve clearances close 4x quicker than inlets.
