1 - 14 of 14 Posts
hi guys i have done some searching but cant find what i need,,im putting the zx 600 into a morris minor and the fuel line set up is confusing..can i get rid of the regulator and just put a fuel pump to the carbs? or any other way some piks realy help cheers
Gas Toy Auto part Machine Metal
‘83 Gpz750 Resto-mod, ‘78 Kz1000 Resto-mod, ‘18 Z900RS
I looked at USA parts diagrams for both a ‘98 Zx6E (Zx600E) and a Zx6R (Zx600G) and neither have a fuel regulator. There is a fuel shut-off valve (petcock), a fuel filter and a fuel pump. No other components between the fuel tank and carbs.
Later, Doug
80,81 GS750L, 81 XS1100, 85 FJ1100, 96 GPZ11 (1200 EFI PROJECT), 03 VT11, 06 VT600, 12 ZX14R, 67 C20
If ur running the engine's fuel pump then u dont (shouldnt) need a regulator, if ur running anything else u might need one, check w the mim-mod guys at the tracks and someone should b able to help u out in that direction
ok guys i got her going but when i put fuel pump on and wen bowls a full fuel comes out of all the inlet pipes like i have to much pressure the fuel lines have me stumped heres some picks cheers there's one pick with fuel line going into the bottom of the carbs
Motor vehicle Automotive tire Electrical wiring Rim Gas
Motor vehicle Automotive exterior Automotive design Gas Engineering
Motor vehicle Automotive tire Automotive design Audio equipment Gas
Fuel pumps for carbed bikes should only be pushing 2-3, maybe 4, psi. The fuel needle valves should be able to shut the fuel off and dead-head the system if they’re working properly.
Later, Doug
Later, Doug
the carb fuel bowls were filthy but now its flooding and still coming out the fuel inlet pipes i think it needs new rubbers...all i really need to no now is the inlet for fuel the bottom line? or is it suppose to run threw the regulator
1 - 14 of 14 Posts
