1 - 9 of 9 Posts
I have a 1995 ZX11D3. Starting with 1995, the ZX11 dash includes a clock.
This is a small issue, but I wonder if anyone has any suggestions.
Today, while setting the clock, the center of the rubber plug that covers the clock set buttons died (rubber hard and brittle). So there is a hole (2-3 mm) through the dash. I can still set the clock, but I worry that water will get into the dash if I don't come up with a reasonable solution. Covered with tape for now. Looks just like this auction:
http://www.ebay.com/itm/96-Kawasaki-Ninja-ZX-11-D-Gauges-Zx11-S44-/400118472597?hash=item5d28eb5f95&item=400118472597&pt=Motorcycles_Parts_Accessories&vxp=mtr#ht_1283wt_1396
I wonder where one might get a new one without buying a whole new dash. The rubber stopper does not have a separate part number, so it can't be purchased from Kawasaki.
Has anyone made one? Other solution?
Thanks in advance.
Solution to clock set rubber stoppers
I ended up buying a broken instrument cluster on eBay that had an intact face plate (i.e., the front plate that covers the instruments, including clock). I just swapped the face plate that included the intact rubber pieces.
Just thought that this would help someone...
That one aint got no rubbers.
You mean laptop keyboard mouse rubs cant be adapted ????
Man, you arent trying hard enough....
1 - 9 of 9 Posts
