I would like to get some anodised (gold or blue) bolts and nuts for the rear rotor and rear sprocket. I know where to get anodised aluminum fasteners that will do the job on a CBRXX, but I don't know if they are up to the task on a '14. Torque specks are lower than stock with these. Titanium is stronger, and looks good, but is really too expensive. Anybody have experience or ideas on this? :bling
· Premium Member
Don't stick aluminum bolts in there.
· Premium Member
http://www.pro-bolt.com/titanium/ti...-suzuki-kawasaki-4mm-collar.html#.TyV8S8UV28A
If you are interested, I have a large assortment of gold anodized aluminum allen head bolts that are great for case covers, lever perches and various other non-stressed attachments. I would let them go for $10+shipping. I took enough out to so the side cases and lever perches on my late, lamented ZZR 1200, but there are a buttload left in the case.
Be careful using Ti bolts for this application, if they are not properly coated with Ti-prep the galvanic reaction between the Ti and the wheel could make it nearly impossible to get the bolt out at a later date. Ti also can sheer rather easily if they are at all over torqued and stretch, on that note the torque for Ti bolts will be different from a steel bolts for the same application. Good luck!
