Hi all,
right i have a problem with power draining from the system. i have a new battery and the alternator is charging as it should be. but i go back to the bike after a week and its flat. there is no alarm or anything else attached that could be a drain.
any ideas?
Make sure you are turning your key to the left when turning off the bike. If you turn it to the right it will still lock the steering but turns the "parking" lights on.
This is know as the battery drain position.
