As many have stated my bike is also experiencing the one bar away from max on a regular basis. I am ordering the aftermarket fan and am no stranger to wrenching. Just got my shop manual so I am pretty much ready to go. Any tricks or short cuts??
I am doing the pipes, PCIII, and some other mods in about a week so I figure I will do it all at once.
Anyone who has done it wanna help a brother out. Thanks in advance.
step 1: buy a shop manual
step 2: enjoy shop manual
step 3: if your replacing stock fan with muzzys, enjoy. watch out for that top plastic piece.
I installed my muzzys, thought I had all the clearance issues out of the way, then went and drove it with out cowlings for 10 miles..I liked it then. Then once I replaced all cowlings, went for a ride..10 min later, the fan turnedon and started hitting the upper black plastic piece above the fan.
I did not want to chop it up, so I went back to stock.
Stock fan is fine....I will install second fan and circuitry that will keep fan on f a few minutes afer I turn off bike. this is best IMHO
step 4: close shop manual, go for a ride
I was informed that the gtr dual fan setup are compatible with the zx14 rad.. Why don't you have a check regarding this... who know's it'll save you a lot of trouble the likes of me and terrible ted went through...
Its real tight clearance with the Muzzy on top. Mine touched initially, but after final assembly it had approx 1/8" to spare. The Muzzy moves alot more air and my bike hasn't gone over four bars since.
I have all the Tupperware off from doing the pipes and power commander and you are not kidding about tight quarters under there. Does not look like a fun job. Thanks for the replies.
