I have a1998 G1 Uk model,it will redline in 1st,2nd,3rd,4th no problems until im in 5th or 6th when in hits a wall and will not accelerate anymore.It has got a californiia model Tps on it,also has an after market exhaust,the carbs are standard as i replaced them completley,before it had dyno jets installed.Its had a new fuel pump and relay,cdi unit ,coils,leads and plugs.the ram air has been checked,also a mechanic disabled the air suction,emissions canister ,valve reed or whatever they are called,would really appreciate any ideas or advice .
Just had a look a parts diagram and it looks like the tps is the same for all.But there are some solenoids attached that are california only.Whip them off and see what happens.Hope this helps.:banghead
